array formatting
array formatting
How to format array of floats using ruby?
Equivalent of "format string" primitive.
For example trim array values to 0.00 or set display like 000.00 and so on.
Re: array formatting
tester wrote:Equivalent of "format string" primitive...
...is the 'format' method. It uses exactly the same format codes as the primitive - which you give as the first argument (in the form of a string), followed by the value that needs formatting... e.g.
@x = Math::PI
format( "%.3f", @x)   #=>  "3.142"
You can include more than just the '%' codes too...
format("The value of PI is %.3f approximately", @x)  #=> "The value of PI is 3.142 approximately"
Or include multiple '%' codes and a list of substitute items to match...
@x = 5.12345
@y = @x * @x
format("The square of %.3f is %.3f", @x, @y)   #=>  "The square of 5.123 is 26.250"
To do this for every item in the array, the method "collect" is the easiest way - or you can call it "map" if you're not so keen on typing! It takes every item in an array, processes it, and then places all the answers in a new array...
@myArray = [1, 2, 3, 4, 5]
@format_code = "%.3f"
@formatted = @myArray.collect{|item|  format(@format_code, item)}
Here's a module based on that code that spits out both a string array and a single string of joined items...
Float Array Format.fsm
(815 Bytes) Downloaded 887 times
PS) There's a full list of the supported format codes HERE.
