25 oscillator synth, Blowtorch, my first synth
synthmaker123
Post by synthmaker123 »
This is my first synth I made after playing around with flostone for a bit, I tried to make a high gain synthesizer.
I basically put a few state variable filters inside of each other and put bit crushers inside the filters too.
The keyboard, oscillators and bit crushers were made by other people, I should point out, - I hope its ok that I used them
----EDIT #2 - I updated it, now it sounds better and the filter knobs have been removed because they did not do to much, now there is only one cutoff knob in there place. It now has 30 oscillators and 2 echo delays and 2 chorus/flangers. The vst uses a large amount of cpu though, here is the direct download url, http://www.mediafire.com/download/f7rr9 ... orch+3.dll
The .FSM FILE for Blowtorch 3
http://www.mediafire.com/download/655benba7ay50b2/blowtorchnew2_led_nonobs.fsm - Its a messy file, I'm kind of a disorganized person
-----Edit, also here is the .fsm file(to large to post here) http://www.mediafire.com/download/ejrrob47nqfpeyk/blowtorchnew2_led2.fsm
The file is 6.67 mb and was to large to upload here, It might be cpu heavy
If you want to download you can from here, http://audionectar.webstarts.com/index.html OR
the direct link http://www.mediafire.com/download/5iktp6u69ev8tfe/Audio+Nectar+-+Blowtorch.dll
http://www.audiocat.net for my synths I made in flostone
