Knob ratio : Compressor
rustyou
Post by rustyou »
Hello !
I have a question,
what is a value of knob ratio (0 - 1) of output : 1:1 ....etc
Exemple knob position 0 = 1:1
knob position (max) 1 = 8:1
How see the reference ??
Thank you
Perfect Human Interface
Re: Knob ratio : Compressor
Hello, I'm not sure exactly what you're asking for, but I added an output to my knobs for the 0-1 ratio as well as the set min/max ratio. Maybe something like that will help you? Or you could just set the knob to 0-1 and then multiply by 7 and add 1 outside of the knob.
rustyou
Post by rustyou »
Hi !
Ex :
How to define three position for my knob :
1:1
2:1
4:1
For this exemple, what is the value for my knob.
limit knob : 0min and max 1
Thx u
Knob outputs just values, whether these represent ratios or something/anything else. You just set the min/max from 1 to N, and you have ratios, for example from 1:1 to N:1.
If you wish to have specific numbers - you can use a selector driven by knob out or if-then-else routine or some sort of down/up rescaling with integers, if this is supposed to be infinite range of regularly defined ratios.
ratio2.fsm
(125.44 KiB) Downloaded 960 times
ratio.fsm
(125.37 KiB) Downloaded 920 times
rustyou
Post by rustyou »
Thank
In out meter monitor.
My compressor will be of knob = 5 --------> out monitor compress = 5:1 value ? exactly ?
Exemple ratio.fsm
Exemple
(13.49 KiB) Downloaded 915 times
Now, connecting second wire to your compressor - remember to scale your green value (on that second wire) appropriately to input requirements of your compressor part, to fit proper ranges there.
rustyou
Post by rustyou »
Eh ...
For this exemple of compressor.
The value of ratio is : min =0 max=1
What the real value in output (1:1, 2:1...etc)
0 = 1:1
0.5= ?
1=?...
Thank you,
Comp.fsm
(190.88 KiB) Downloaded 957 times
