Storage Scope Example
This example uses the Direct Sound in from the PC soundcard as a trigger signal for the Storage Scope module. If you have a microphone connected just tap the Mic to see the signal sampled on the scope trace.
The Gain is the input sensitivity, the Time (ms) is the time of the waveform captured, the Trigger Now forces an instant trigger, the auto trigger samples a single shot or multiple shots automatically, and the trigger level is the level at which the scope is triggered.
The default setting should be enough to demonstrate the basic function of the Storage Scope Module.
- Storage Scope Test.fsm
- Storage Scope test file
- (45.46 KiB) Downloaded 3393 times
