Com Port Module
Com Port Module
The Com Port Module has a Ports Output of available ports.
How does one take this array & use it with a Gui Selector module ?
Albert Einstein
Albert Einstein
Re: Com Port Module
If you add a text box connected to the com port out, it will show available ports,then you could feed this info back into a selector (in my example I used a menu) so you can now select one of the available com ports as input. Not sure if this is what you meant.
- ComportExample.fsm
- (1.06 KiB) Downloaded 3943 times
- SP32-20140607-092401.jpg (22.88 KiB) Viewed 87613 times
Solved: Com Port Module
That's what i did in a simpler way;
Ports-->Selector-->Port
Much appreciated
Much appreciated
Albert Einstein
Albert Einstein
