display error
rustyou
display error
Post by rustyou »
Hello,
I've a calcul who display the error : 1.#INF
Because the calcul is : 0/0 . this is normal
But for the user, i would like display 0 .
How shall we do it?
Thanks
calcul.fsm
(7.49 KiB) Downloaded 972 times
Drnkhobo
Re: display error
Post by Drnkhobo »
TheOm
Re: display error
Post by TheOm »
Very simple. Just check if the result is infinity and use a selector to display 0 instead.
calcul.fsm
(2.63 KiB) Downloaded 995 times
rustyou
Re: display error
Post by rustyou »
Oh yes perfect thank you.
And for the flaot.
I want to display just one 0 for the user and no 0.0. But i want to display the decimal too....?
TheOm
Re: display error
Post by TheOm »
Like this?
calcul.fsm
(1.58 KiB) Downloaded 1009 times
Re: display error
@TheOm - can you check if you can open your last schematic by double clicking on it?
It's one of these cool examples, that crash Flowstone. ;-)
BTW, if it crashes on your machine as well - send it to support.
rustyou
Re: display error
Post by rustyou »
Yes great :)
thank you for your help TheOm
TheOm
Re: display error
Post by TheOm »
tester wrote:@TheOm - can you check if you can open your last schematic by double clicking on it?
Sorry can't check. I'm using the FL-Studio plugin version, so I always have to use the Open-File dialog.
Re: display error
Okay, I sent it to Malc.
This is one of these situations in which when you start the schematic by double click on it (i.e. not drag and drop to FS nor load via menu) - it crashes FS. I checked on two machines and is the same. Appearently it has to do with some sort of initialization order between FS guts and ruby.
@Nubeat7 - it's one of these spooky scenarios I talked about. Probably will be fixed with the next release.
Re: display error
Post by Nubeat7 »
tester wrote: @Nubeat7 - it's one of these spooky scenarios I talked about. Probably will be fixed with the next release.
no idea what you are talking about? everything works normal here...
