Fade In LFO - Best Technique
Tronic
Post by Tronic »
Which technique you use to implement a fade-in to a LFO?
The concept would be to have a single envelope with attack and control the amplitude-stream of the LFO,
but as you well know to implement an envelope is always linked to a stressful computing for CPU,
you know or use other techniques to do this?
Exo
Re: Fade In LFO - Best Technique
Post by Exo »
For a synth?
Something like this should be enough....
streamin lfo;
streamin fadeInTime;
streamin sampleRate;
streamout fadeInLfo;
float increment;
float fadeIn;
stage(0)
   increment = fadeInTime / sampleRate ;
   fadeIn = 0; //reset for every new voice
fadeInLfo = fadeIn * lfo;
fadeIn = min(fadeIn + increment, 1);
That should work for you. I don't think there is a simpler way than that.
Or alternatively you may use exponential fade in (basically the same idea of implementation as Exo's but different envelope shape)
streamin lfo;
streamin fadeCoeff; //this is number usually around 0.9 (always 0-1 range)
streamout out;
float cut=1;
out=lfo*(1-cut); //cut is 1 on start and decays to zero over time
cut= cut*fadeCoeff; //fade coeff controls how fast cud decays
fadeCoef has to be calculated too. Generally it is e^(-1/T) where T is release time in samples.
Note that Release time is not the time it takes for the decay to reach 0, but 0.3679 instead. (exponential curve never really reaches 0).
Exponential curves often sound more natural to human eat than linear.
Tronic
Post by Tronic »
Thx for this code hint.
