SAMPLER vst or exe?
apoc123
SAMPLER vst or exe?
Post by apoc123 »
does anyoneknow why when i create a sampler, as soon as i connect the ouputs to an asio and try to export as a vst, it only lets me make an exe??? i have the full flowstone version.... help guys!!!
Re: SAMPLER vst or exe?
Post by Nubeat7 »
do you have an input?
if you have no input (midi for vst instrument and audio or audio and midi for vst effect) you only can export as an exe.
To make a VST, you need all of the 'workings' of the plugin inside a module container, but the ASIO/MIDI primitives outside the container. The connectors where you join your module to the drivers then become the inputs/outputs of the plugin (audio links must be blue mono).
For an exe, everything, including the driver primitives goes inside.
apoc123
Post by apoc123 »
nubeta7.... yes I have the midi in selector and the keyboard highlighted.......thanks for the help though!
trogluddite.....I think that was my error I had everything inside!!! thanks man!!!
apoc123
Post by apoc123 »
Can you guys edit this sfz player so that I can export it as a vst and load sfz....it only lets me make a exe........help!!!
SFZ PROBLEM.fsm
(72.12 KiB) Downloaded 998 times
Exo
Post by Exo »
Hey, you just need a module with a midi input and two mono outputs.
I've modified your example....
SFZ PROBLEM.fsm
(74.97 KiB) Downloaded 1066 times
