FL Flowstone Schems
Flemming
FL Flowstone Schems
Post by Flemming »
Hi guys,
Last night i realized, since i also own FL Studio, that FL Flowstone is FULL of nice schems which i can dissect and learn from ;) (i hope this is not breaking any agreements/licences or anything like that?!). I downloaded all of them from inside FL Flowstone, and then i loaded them into regular Flowstone to save them again (converting the files from osm to fls).
Of all the 111 schems, only 6 generators had problems loading into Flowstone 3.0.5:
- Invector.osm
- SMG Retronix 2.osm
- SMG Retronix LE.osm
- SMG Retronix.osm
- SMG Wavedraw.osm
- UniRetro.osm
If i load one of the above files, Flowstone will crash immediately. So i was thinking if there is some way to open them without it crashing? Like a failsafe mode, or opening the files without their audio streams running to maybe avoid the crashing?
Re: FL Flowstone Schems
You may try disabling all your playback devices in windows. Because there will be no playback devices, FS schematic with engaged soundcard output will load turned off and you may solve the problem while the streams are disengaged (however, you will not be able to test it until you turn on your playback devices and reopen FS, cos' it scans for audio devices only on startup). It may help if your problem is in blue (or poly). If it's in green then I do not know of any way to salvage the situation.
Post by billv »
Flemming wrote:So i was thinking if there is some way to open them without it crashing? Like a failsafe mode, or opening the files without their audio streams running to maybe avoid the crashing?
maybe you can try this ....myco gave me this when I had a dead schematic...
http://www.dsprobotics.com/support/view ... 1670#p7562
Flemming
Post by Flemming »
Thanks for the suggestions, guys. I managed to load the last schems in somewhat working condition. At least i can have a peek inside. Here i find all sorts of goodies, like the 'ADSR4' prim, which doesn't seem to be available in 3.0.5
Should i suspect such prims to be outdated in some way, since they're not available for use any longer?
