Triggers Per Seconds Counter
Youlean
Post by Youlean »
It calculates how many triggers where received per second. It is sample accurate.
NOTE: ASIO/DS/Audio Out is needed to be present in the schematics.
Triggers Per Seconds Counter.fsm
(3.25 KiB) Downloaded 1162 times
Perfect Human Interface
Re: Triggers Per Seconds Counter
Hi Youlean. I made a much simpler version. :)
FYI, timing in green is not accurate in general, and the ticker primitives are based on very inaccurate Windows timers. Timing in Ruby is quite accurate though if not perfect (but once it's converted back into green it can't be considered 100% accurate).
Triggers Per Second v1.1_PHI.fsm
(28.23 KiB) Downloaded 1145 times
Youlean
Post by Youlean »
Perfect Human Interface wrote:Hi Youlean. I made a much simpler version. :)
Cool, indeed it is simpler...
BTW, do you have any site with all your work with Flowstone?
All my projects are still WIP. I'm still a good bit newer to Flowstone than most of the other regulars here. I know some of them have some cool things they've made over the years. When I release some things I will post about it.
