Audio Logger Like in Fruity Limiter
Youlean
Post by Youlean »
Peak will be always correct, but the rest depends on tick performance...
Audio Logger.fsm
(10.28 KiB) Downloaded 1092 times
Re: Audio Logger Like in Fruity Limiter
There is a way to overcome the green tick problem. You may create a memory buffer and write mono data into it in a circular fashion. Then use mem to float array to extract the data and shift it by inverse of the index that is used to write the data. By changing the size of the mem and decrements of the index calculation you may change the speed and area.
audio logger.fsm
(122.16 KiB) Downloaded 1232 times
Youlean
Post by Youlean »
KG_is_back wrote:There is a way to overcome the green tick problem. You may create a memory buffer and write mono data into it in a circular fashion. Then use mem to float array to extract the data and shift it by inverse of the index that is used to write the data. By changing the size of the mem and decrements of the index calculation you may change the speed and area.
Cool workaround! The bad thing is that display have some graphical glitches (mine also has)...
