is there a way to get a trigger that confirms...
Is there a way to get a trigger that confirms, that gui element was refreshed/redrawed? Something sent from somewhere after successful redraw. It's for operations on hidden elements, and it can't be done with timers.
(FS304)
Perfect Human Interface
Re: is there a way to get a trigger that confirms...
Off the top of my head, you could route whatever triggers are going to the redraw prim to wherever else you need it and just use a trigger switch with the Editor Open prim to block the triggers if the window is closed.
Not sure if that's good enough for what you're trying to accomplish.
Tronic
Post by Tronic »
i use this:
def draw v
    output 0, nil
it send an trig every time the portion of view is refreshed.
Tronic - you just saved my project, thanks. :-)
PHI - I mean something like this (schematic).
Basically, the scenario is like this. Some amount of data is calculated in the background, and a dynamic sized image (a sort of color map) is created from that calculated data. Now - using stock prims to save custom bmp like that is tricky. First - data must be calculated, second - (invisible to user but still present) image must be created from these data, and after all portions of that image are present on the invisible display - bitmap can be saved. But without trigger that confirms, that the image was refreshed - how the saving trigger can know, when to take a snapshot? One way to workaround this - is to use trigger collector from data nodes, and delay after that - in the hope, that all operations will be done before it fires.
The triggers (set in simple order) to area redraw and then to saving the bitmap - seem to not wait until redraw is complete, so it's good that ruby can tell on "v" node, that the image is created. Hopefully this will work fine, but I will check it tomorrow.
refrr.fsm
(1.04 KiB) Downloaded 933 times
Tronic
Post by Tronic »
when I can is always a pleasure to help
It appears, that although solution is interesting and theoretically proper - it seems to not work in real life circumstances (while area is refreshed - otherwise it would not produce a picture - mgui isn't triggering; but the problem may be more complex - including ruby itself and it's excessive processing stuff). Getting back to work around. Longer delay should do, I guess...
