Control standard EQ parameters with knobs/switch?
Hi Guys,
Sorry if this is a super-noob question.
I am trying to control the parameters from the standard flowstone parametric EQ using knobs and a switch, I have tried so many different methods, but so far the only thing i got to work, was to connect straight to the Peaking filter modules, but that doesn't change the display :/
I have attached a quick schematic in case my description is confusing
Tanks in advance!!
Boom
Tanks in advance!!
Boom
- Parametric EQ Control.fsm
- (54.65 KiB) Downloaded 1164 times
Re: Control standard EQ parameters with knobs/switch?
what are you trying to do?
Do you mean you want the EQ to be controlled by knobs instead of the draw? i think you need to rebuild the eq then.
Ideally, I plan to have control via both methods, if this is possible?
Maybe there is one schematic already floating around with this capability
I think you need to remake whole module like a new eq. im not sure but think so.
I have done this once-
You can find it here-> http://www.phonicsaudio.com
It's in effects and called freQ
I would be willing to sell you the schematic
So it's possible
edit-fixed link
So it's possible
edit-fixed link
LoL i like the Link
Thanks for the option, for now I feel it would be better learning experience to try and create it myself, even if its with the help of others, if I am still stuck I might take you up on that option, great looking EQ btw
