Midi GUI Keyboard
- Loopeytunes
- Contact:
Midi GUI Keyboard
DJBrynte asked for a keyboard module a few days ago and I made a quick keys module for him.
Here it is:
Update Log 27-10-14
Added:
- Set keys corner radius.
- Gradients on keys.
- Turn on or off the gradient.
- Transparency on the "Pressed" colour.
- Black key highlight gradient.
- Turn on or off the black key highlight.
Bugs Fixed:
- N/A
Update Log 26-10-14
Added:
- Redraw limiter (added by Exo)
Bugs Fixed:
- Double Trigger Note event when mouse clicking.
I will update this (when I get the chance) and add more user customization in it.
Here it is:
Update Log 27-10-14
Added:
Bugs Fixed:
- N/A
Update Log 26-10-14
Added:
Bugs Fixed:
Re: Loopey Keys
still not working with selectors? :/
Re: Loopey Keys
hi loopey tunes,
your keyboard doubletriggers note events,
you should choose between mLDown/Up or the drag on/off bool to trigger note on/off events instead of using both.
- Loopeytunes
- Contact:
Re: Loopey Keys
Thanks, I'll take a look at it later today and fix it.
Re: Loopey Keys
Hi Loopey,
I fixed your keyboard so that it works with the old selector. It will need some more testing though because I am using the Thread primitive which is R&D, and I currently don't have a midi keyboard to test if it works with 'real' Midi.
- Loopeytunes Keys v1.1.fsm
- (8.95 KiB) Downloaded 1241 times
- Loopeytunes
- Contact:
Re: Loopey Keys
EDITED:
Ok my mistake, I turned the wrong MIDI device on lol it does work with "Real" MIDI.
Thanks
Thanks
Re: Midi GUI Keyboard
Try this one...
- Loopeytunes Keys v1.0fix2.fsm
- (9.1 KiB) Downloaded 1284 times
Re: Loopey Keys
Loopeytunes wrote:EDITED:
Thanks
Lol the new one I just posted is probably better anyway (if it works fine) because it doesn't rely on the Thread primitive.
- Loopeytunes
- Contact:
Yep that works
I've sorted the double trigger note events problem that Nubeat7 mentioned, thanks
Used your fix Exo and updated the file in the first post. Thanks
Loopeytunes wrote:Yep that works
Great, thanks for sharing the keyboard
