Help with Morphing X/Y Oscillator
glitchcpt
Post by glitchcpt »
Hey guys,
So I had an idea for an oscillator using an X/Y to morph between 4 different shapes,
but again I think I have gone blank on the maths for how its suppose to work, the result I have so far is an interesting effect but it is not exactly how I wanted it, basically the idea is to have the exact waveform when the cursor is in one of the 4 corners of the X/Y and then it slowly morphs into the other waveforms the closer it gets to the other corner.
Thanks for your help guys :D
xy osc.fsm
(24.19 KiB) Downloaded 1194 times
Re: Help with Morphing X/Y Oscillator
so you have 4 oscillators. Lets name them based on the XY position that specifies them. We use Y coordinate to morph between left top and left bottom as well ass right top and right bottom. Then we use X coordinate to morph between the result of left side and right side.
glitchcpt
Post by glitchcpt »
Yes, that is exactly the idea.
They seem to pop out the other side as sums of each other etc
:edit:
I think i see where I went wrong :)
glitchcpt
Post by glitchcpt »
Thanks for your help!
Got it working, here it is:
xy osc edit.fsm
(22.11 KiB) Downloaded 1215 times
Post by Nubeat7 »
nice one thank you Glitchcpt for sharing it.
Perfect Human Interface
Shouldn't they just be sums anyways?
glitchcpt
Post by glitchcpt »
Perfect Human Interface wrote:Shouldn't they just be sums anyways?
My idea was to have the pure waveforms when the X/Y selector is in one of the four corners :D
glitchcpt
Post by glitchcpt »
So I am trying to add a second oscillator, using the same panel, OSC1 using left click and OSC2 using right click.
The right clicks code, doesn't release the node when I let go of the mouse button, I think I missed something in the original code,
the example is attached :)
xy osc edit Rclick.fsm
(160.27 KiB) Downloaded 1193 times
The "mouseRUpcaptured" method should be named "mouseRUp" ...You just did a typo I believe.
glitchcpt
Post by glitchcpt »
I just copy pasted from someone elses code, so that is probably the case :oops:
