deleted by uploader
deleted by uploader
deleted
Re: "Saving" the "Selectors Sequence Setting"- Possible?
You can do that with the txt save and load prims. See the attached example. It saves your sequence at the exe folder and reloads it if you start the exe.
- Selectors Setting Sequence - Save.fsm
- (33.57 KiB) Downloaded 801 times
