Audio Gain and EQ
Audio Gain and EQ
This example uses a Voltage Controlled Amplifier (VCA) to control the volume of the audio signal coming from the Sound Card and a State Variable Filter to change the EQ settings.
Try playing some sound into your soundcard and listen to the results as you move the knobs.
- Audio Gain and EQ.fsm
- VCA and State Variable Filter
- (30.01 KiB) Downloaded 3441 times
