Toggle and Flip-Flop module
Simple but useful, why are not listed as primitives ?
Toggle: alternates the logic output after each trigger. Flip-Flop: a logic memory, with set and reset
Re: Toggle and Flip-Flop module
You can find something similar in the switch. Also the last "Not" in the toggle seems not to be needed.
Cheers.
Cheers.
The last '"NOT" is just for initializes the output module w/ "0'" logic.
brgds
brgds
Here's an alternative Flip-Flop that is simpler and safer.
- FLIPFLOP-2.fsm
- (535 Bytes) Downloaded 2189 times
DSP,
Understood, tks !
brgds
Understood, tks !
brgds
fixstuff555
Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?DSP wrote:Here's an alternative Flip-Flop that is simpler and safer.
Indeed, I am also a beta tester!fixstuff555 wrote:Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
fixstuff555
Sweet... Can't wait to see it!DSP wrote:Indeed, I am also a beta tester!fixstuff555 wrote:Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
