Help: Ruby 4 x Sample & Hold Value
Walter Sommerfeld
Post by Walter Sommerfeld »
Well... this Value thing in ruby makes me crazy...
I need ur help guys:
What i need are 4 sampled values... sounds easy but:
i can't get it to work :o
maybe it should be done all in one ruby part?!
and maybe i'm missing here something :?
So just simply click the dice 4 times and try to recall the sampled values with the knob :(
Walters dice 4 x Value Sample.fsm
(please ignore the simple dice part)
(264.29 KiB) Downloaded 851 times
Tronic
Re: Help: Ruby 4 x Sample & Hold Value
Post by Tronic »
semplify all with this?
watch 'number', number = [ [*1..6].sample, [*1..6].sample, [*1..6].sample, [*1..6].sample ]
number[@select] # the var @select is an ruby int input named select
Walter Sommerfeld
Hi Tronic,
thanks but:
i only need a value selector that is working (see the not changing output label when u rotate the knob)
...ignore the dice part
Tronic
Post by Tronic »
Yes the ruby connector not have the same concept of the green < - >, so you have retrigger it with the ruby.
However the my example is the simply version of your schematics, it act in the same manner, just use an knob to get the value of results.
def event i
	if i=="dice" # get trig from dice button?
		output 0, a=[*1..6].sample
		output 1, b=[*1..6].sample
		output 2, c=[*1..6].sample
		output 3, d=[*1..6].sample
		@number = [a,b,c,d]
	output 4, @number[@select] #@select is knob input value
Walter Sommerfeld
I need 4 sampled values selectable from the same value source!
Not four selectable random numbers.
The dice is only a simple 'generator' to get 4 values for the selector!...
Please have a closer look - Thanks again
Walter
Walter Sommerfeld wrote:I need 4 sampled values selectable from the same value source!
Walter
Something like this?
EDIT: No, can't be what you're looking for, I just saw that Tronic already offered bqasically the same, meaning a selection is done by the knob from a pool of several values.
selection.fsm
(4.46 KiB) Downloaded 830 times
Walter Sommerfeld
YUP tulamide,
but thanks anyway...
U guys put me on the right track...
but i guessed it ends up with a selector made inside a ruby mod by using variables to mimic the S&H...
My intention
here is needed because i have a very complex Midi Controller project where i need to S&H 4 banks of values so i don't have to calculate them every time again and again!
After ur hints and sleep over it i think i got it (on paper)... ;-)
Will report later...
Walter Sommerfeld
Here my working if/elsif version!
If some of u like to make a simpler version with in 'case' etc. - you're welcome...
keep on doing!
Walter
4 Values s&h in ruby by sunsynth.fsm
finally it is working (i hope)
(15.54 KiB) Downloaded 818 times
Tronic
Post by Tronic »
this is my simplification
def init
@SH = []
def event i, v
	if @on and (i=='go') and (@selection<=@max)
		@SH[@selection] = @input_value
	output @selection, @SH[@selection]
	output 'done_v', nil
	output 'done', nil
Walter Sommerfeld
works fine... but:
where my version triggers one time after hit go - yours produces 3!
cheers,
Walter
