Auto Correlation
Auto Correlation
This example shows how to use the Auto Correlation Module to correlate a signal with itself or two separate real-time signals.
In this case a sine wave input is used and correlated with itself, the slider controls the delay factor for the Correlation
The real-time Correlation factor is output as well as the average correlation factor.
Basically the output is highest when the two signals match or are in phase.
- Auto Correlation.fsm
- Auto Correlation
- (26.78 KiB) Downloaded 2935 times
