I need some help with MIDI.(Solved.)
Parki
Post by Parki »
I hope my english will understeandable. Sorry if it not so.
We can change a midi data to a plugin in Patcher, but does it possible to make it for all plugins?
I mean "Can I change the main midi input in FL studio?".
I will appreciate if someone help me with it,
Because I really need this thing and I don't know how I could make.
To contact write here or add me on Skype(parkidesu).
I hope my english was understeandable.
Skype id - parkidesu
Perfect Human Interface
Re: I need some help with MIDI.
To send MIDI from FL Studio to Flowstone use the "MIDI in" module. If you want to send MIDI to a Flowstone effect, load up a "MIDI Out" plugin in FL. You can use "filter port" module to select a specific port number, and set the same on the MIDI Out.
To send MIDI from Flowstone to FL Studio, you'll have to use a VST format plugin, not any of the "Fruity" format plugins that come with FL Studio. Once you've loaded a VST plugin, in the top-left corner of the plugin window there will be a small gear button; if you click on that you'll find options where you can select a MIDI input port. Set that to the same port number you output MIDI from in Flowstone.
Parki
Post by Parki »
At first thank you for reply for I'm very glad that some understeand this stuff.
I won't be annoing but it doesn't work on my side still.
Could you test it from your side?
Just to except that isn't your wrong.
Could it be depend with a bug that was in Patcher(Flowstone has no MIDI output)?
I haven't really used Flowstone with Patcher yet. I might be able to check it out later.
In the mean time, if you want help with a bug or something not working, often it's best to upload a project file here so others can look at it.
Parki
Post by Parki »
Sorry it's work.That was my bad, I did a stupid mistake.
But what a pity that we can't to the same with the "Fruity" format plugins that come with FL Studio.
Parki wrote:But what a pity that we can't to the same with the "Fruity" format plugins that come with FL Studio.
Actually now that I think of it I believe there is a way to do so within Patcher. I don't really use Patcher but I've seen others asking about it on the IL forums. Let me see if I can find it.
Right, you just right-click on the From FL Studio module and you can select a MIDI port under outputs. Then you can wire that output to whatever you need.
