It looks simple.
Parki
It looks simple.
Post by Parki »
It looks simple: A is integer, when A is changed(time intervals undefined) the code returns different between the new value and the old.
Could anyone solve this problem?
Because I already four day can't solve this.
I hope my english was understeandable.
Skype id - parkidesu
Re: It looks simple.
This should work...
use the "sample and hold" prim. Calculate the difference between it's output and the input and hit sample and hold to update its value.
green diferentiator.fsm
(256 Bytes) Downloaded 844 times
Parki
Post by Parki »
But it's don't work.
try this...
(290 Bytes) Downloaded 846 times
Parki
Post by Parki »
Why does it happens to me?
green diferentiator module problem.fsm
(1.71 KiB) Downloaded 856 times
Youlean
Post by Youlean »
Will this work?
(348 Bytes) Downloaded 826 times
Xtinct
Post by Xtinct »
Parki wrote:Why does it happens to me?
Check link /trigger order
