BLDC and stepper motor driver with FS
Hi all,
here is a demo of 3phase PWM signal generation which could be used to drive BLDC motors...
I'm newcomer to the DSP tool, modifications to the 3-phase generation are welcome !
(Tnx trog for the scope, is a great help !)
I am seeking a way out of FS to the real world.
Has anyone gained experience with hardware IO (other than audio) which is fast enough to follow these realtime generated FS signals ?
Does multi channel audio work through ASIO provided the hardware is present ?
Any hints welcome, thanks in advance !
Regards Tom
Regards Tom
- PWM_1.fsm
- (216.13 KiB) Downloaded 4469 times
curiosity makes us progress !
Re: BLDC and stepper motor driver with FS
Hey mate,
I'm pretty useless with machine control,
but 128khz control signals are realisable with sound cards.
Here is a system for dc uncoupling->
http://www.expert-sleepers.co.uk/siwacompatibility.html
I will check your 3-phase schematic, but my grasp of the use of separate phases is hopeless, like I say hehe
Here we have discussed stepper motor control
(I have wired a bipolar one to a physical knob at one stage)->
http://www.dsprobotics.com/support/view ... f=72&t=529
I have plenty of multi-channel ASIO experience, and it's a solid tech generally,
ie. I have had hardware die but little soft niggles
Pulses r cool!hehe
I am into fast signals too, if you find anything interesting out.
I have used audio to make tachometers that read above 3000hz fine.
Pulses r cool!hehe
