Me.Problem.Again.(Solved)
http://www.dsprobotics.com/support/viewforum.php?f=23
Here at 153 page has a Ruby code.(look at the file below)
I copyd(how to write it right?) the code and it's doesn't work.
What am I doing wrong?
- 153, counter by Ruby.fsm
- (1.11 KiB) Downloaded 785 times
I hope my english was understeandable.
Skype id - parkidesu
Re: Me.Problem.Again.
You named the input exactly the same as the variable. They can't both have the same name. Rename the variable and it will work.
Yep, that's works. Thank you.
