Midi Output
Midi Output
I am interested in using a Midi Control Surface with motorized potentiometers/faders to act as inputs and controls for some robotics. The record/playback motif would be interesting for playing back servo positions.
I have been unable to get the Midi Out module to put out any signal, my USB MIDI converter has an output indicator LED as well as I ran every possible combination into the module.
Are there any insights or examples for the MIDI output for controller output messages?
Thanks all,
Bil
Thanks all,
Bil
Re: Midi Output
Here's a simple Midi Note Out test:
- Midi NoteOut Test.fsm
- (2.99 KiB) Downloaded 1428 times
Re: Midi Output
That DID work, thank you. I had the same layout only I had the MIDIEvent module instead of the NoteEvent module, whats the difference?
Can I send a MIDI string that isn't "note" based? I suspect that that the "controller" set is not considered to be a note.
Is there a way to convert the MIDI sting to text for viewing or converting a string to MIDI so I can construct my own MIDI commands?
Much thanks and best regards!
Bil Herd
Bil Herd
Re: Midi Output
You will need to check in the manual for your controller what messages control what. You can do everything with the Midi Event Module you just need the right codes.
Status = 11 (0xB) = Controller message
Channel = 1
Data 1 = Controller number
Data 2 = Data (0-127)
You can check what the standard midi messages are here:
http://www.midi.org/techspecs/midimessages.php#3
Here is an example of sending out a midi controller message.MIDI data messages are composed of four distinct parts. Each part is an integer value. The parts are
as follows:
Status - (0-127) the type of MIDI event
Channel - (1-16) the MIDI channel on which the event was received
Data 1 - (0-127) the first byte of data received (for note events this is the note pitch)
Data 2 - (0-127) the second byte of data received (for note events this is the velocity)
The MIDI Event component takes this information and creates a MIDI event message.
Channel = 1
- Midi Controller Out Test.fsm
- (11.25 KiB) Downloaded 1419 times
