Edit Box - Set not editable
Nowhk
Post by Nowhk »
Is there a way to put Edit Boxes devices not editable? I can put the mouse, delete and write what I want. I'd like to avoid this...
Re: Edit Box - Set not editable
Post by Nubeat7 »
use a label then, or block any mouse action
Nowhk
Post by Nowhk »
Label has not S pin input. How would you block mouse action? This is not enough:
Post by Nubeat7 »
Nowhk wrote:Label has not S pin input..
just create one with "i" on your keyboard ;)
maybe it would be good to read the manual (page 63)
Nowhk
Post by Nowhk »
Oh, I can use "I" for every element! Nice ;) Didn't noticed this. Thanks!
Unfortunatly I can't set a background, but I'll use a "back" image behind the label.
Perfect Human Interface
Nowhk wrote:Unfortunatly I can't set a background, but I'll use a "back" image behind the label.
Use a "filled rectangle" prim and wire the view from the MGUI and the area (use "view to area") and a "colour" prim to the inputs. Make sure the order of the view connections is correct so that you don't draw the rectangle on top of the text.
