(RUBY) Splitting array into array of pairs
Just a little line of code for those, that have an array of values they want to organize in pairs.
Say, you have this: [xvalue, yvalue, xvalue, yvalue, xvalue, yvalue, xvalue, yvalue, xvalue, yvalue]
newarray = myarray.each_slice(2).map {|n| n}
will create [[xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue]]
You can have any length of the subarrays by adjusting the number of elements per slice, e.g. each_slice(3) == triplet
Just make sure to add the dummy map. each_slice just returns either an enumerator or nil, so it's needed. You can chain each_slice to create further layers.
newarray = myarray.each_slice(2).each_slice(2).map {|n| n}
Based on the example, will create
[[[xvalue, yvalue], [xvalue, yvalue]], [[xvalue, yvalue], [xvalue, yvalue]], [[xvalue, yvalue]]]
Happy Programming :)
Re: (RUBY) Splitting array into array of pairs
Just to add... to reverse the process simply use "flatten"
newArray=arrayOfPairs.flatten
it will convert:[[xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue]]
to [xvalue, yvalue, xvalue, yvalue, xvalue, yvalue, xvalue, yvalue, xvalue, yvalue]
also it will convert: [[[xvalue, yvalue], [xvalue, yvalue]], [[xvalue, yvalue], [xvalue, yvalue]], [[xvalue, yvalue]]]
Flatten also accepts an argument, which specifies the depth of flattening:
newArray=arrayOfPairs.flatten(1)
in this case: [[[xvalue, yvalue], [xvalue, yvalue]], [[xvalue, yvalue], [xvalue, yvalue]], [[xvalue, yvalue]]]
will be converted to: [[xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue], [xvalue, yvalue]]
