Ruby. A problem with composition.
Parki
Post by Parki »
Is it possible to make this without going A class outside?
Because when I trying to run the second one it's won't work:
class A
	def initialize
		@a = 0
	def event_stuff
		@a += 1
	def get_a
		@a
class RubyEdit
	def init
		@a = A.new
	def event
		@a.event_stuff
		watch @a.get_a
class A
	def initialize
		@a = 0
	def event_stuff
		@a += 1
	def get_a
		@a
class B
	def initialize
		@a = A.new
	def get_a
		@a
	def watch_a
		@a.get_a
class RubyEdit
	def init
		@a = B.new
	def event
		@a.get_a.get_a
		watch @a.watch_a
I hope my english was understeandable.
Skype id - parkidesu
MyCo
Re: Ruby. A problem with composition.
Post by MyCo »
not sure if I understand correctly, but I think the problem in the second code is here:
class RubyEdit
   def init
      @a = B.new
   def event
      @a.get_a.get_a  # <<--- "get_a", not "event_stuff" ?
      watch @a.watch_a
Like Maik said, if you are wondering why the second one doesn't count up, it's because "event_stuff" isn't called. Otherwise, you should provide an example of what you're trying to achieve.
