Center Isolation in Flowstone
chackl
Post by chackl »
Hello!
Did anyone do some kind of center isolation in FS / SM?
In audacity they have an effect called Vocal Remover and Center Isolation that realy gets good results.
Source Code of the Effect:
https://github.com/audacity/audacity/bl ... lrediso.ny
But translating this into FS may be a little to tricky to me.
Thanks!, C.Hackl
EDIT: Since the Usage would be an own upscaling from stereo to 7.1 it is not that important to get that plain results.
Re: Center Isolation in Flowstone
Post by k brown »
Center removal in a stereo source ('Vocal Remover') is easy - one channel to non-inverted vca, the other to an inverted one; when these two are summed together, anything that's identical in both channels will be removed. Center isolation is much trickier and I assume would require DSP.
chackl
Post by chackl »
Hi!
Yes i did some experiments with mid/side conversation that you decribed. But this was not the result i expected.
Doing a Center Isolation and subtract this from the original source would give you a "wide" stereo without any center in it. I could not get this result by using a mid/side conversation.
Regards, C.Hackl
Post by k brown »
Not sure I follow you - I didn't mention anything about mid/side conversion.
Mid-Side hasn't anything to do with center removal or center isolation from a stereo signal, but is rather a circuit for extracting a stereo signal from two mono ones - an omni (or, occasionally forward-facing cardioid or subcardioid) microphone coincident with a side-facing bidirectional mic. The mid-side matrix converts these two signals into a left/right pair of coincident cardioid patterns ('X/Y') with variable angles to each other.
I'm guessing you're referring to software that simulates these two mono signals extracted from a stereo one, but even assuming these do what they say, it wouldn't get you what you're after; the signal equivilant to the center omni mic would contain all sound coming from every direction, and not just the center info from a stereo signal, such as isolating a vocal from a stereo mix.
chackl
Post by chackl »
Well the mid/side schematic i remember is quite old. Maybe it was just named unhappy.
I'll refere to this one and to some tests:
http://www.moitah.net/download/latest/C ... ut_GUI.zip
It also contains a commandline tool:
Center Cut CL v1.6.0
Copyright 2006-2010 J.D. Purcell
Center Cut algorithm by Avery Lee
FFT library by Takuya Ooura
Arguments: source_file [switches]
Switches:
  -s <file>     Write side channels to file.
  -c <file>     Write center channel to file.
  -a <percent>  Scale output amplitude by percent (default 100).
  -d            Dual-mono center channel.
  -b            Move bass to side channels.
  -o            Overwrite output files without prompting.
"stdin" or "stdout" may be used in place of input or output files.
I'm not shure if I will get the results i am expecting - i may have to test it within the next days. :)
I'll lean far out the window here, so maybe it's nothing substantial for you. Anyway.
The basic thought behind vocal removement is that vocals tend to be mixed very centered. A vocal remover you describe (from Audacity) will not succeed if the vocals are not mixed centered.
To "remove" (actually it's more like suppressing) the vocals, you first would do a standard mid/sides, 0.5 * (left - right) for the sides, 0.5 * (left + right) for the mid, and then you can cancel out one of these by running it against the original via sides - original or mid - original. The former would amplify the vocals, the latter suppress them. But of course, it is highly dependend from the mix of the source, and it isn't fool proof.
chackl
Post by chackl »
Hi!
Yes but still "Center Isolation/Remover" - So i am not searching a vocal-remover.
The CenterCutCL tool did fit my needs at the moment. It is sounding a little different than the Audacity Center Isolation. (and sometimes a little metalic what can adjusted by remixing them with some gain adjustments)
So at the moment i can start up my developments on this tool here. :)
Thanks
