deleted by uploader
deleted by uploader
deleted
Re: Image Resizer v1.3
if you want to zoom in for bigger sizes as the original or loading bigger images then the display the sliders are not working correctly, you just see a part of the image, to fix this issue you would need to use the translate primitive..
i did a 'zoom and scroll' module once for your colorpicker tool which should do the job correctly..
- image zoom and scroll nubeat7.fsm
- (70.04 KiB) Downloaded 1187 times
