InterProcessCommunication
Clemens W
Post by Clemens W »
Hi Guys :-)
I wanna make a couple of vst's which need be able to realtime-communicate with each other while running on my daw-tracks. There is already a wonderful introduction into this topic which shows how to share some float values with a dll. http://www.dsprobotics.com/support/view ... f=3&t=2586
But my PROBLEM is: After a half year of trying I don't find a way to pass a STRING from one vst to anonother. Floats (Frames) always work fine, but I wonder why it doesn't work with strings, although I rewrote the c++ file for using strings...
Has somebody an idea? Are there maybe other ways to have InterProcessCommunication over RAM with strings?
Thanks
Re: InterProcessCommunication
I've heard, that flowstone uses the same ruby interpreter in all its instances. That means ruby shares constants and class variables between plugins. I have not tested it myself.
Maybe this clears it (read Myco's post): http://www.dsprobotics.com/support/view ... 560#p17527
Clemens W
Post by Clemens W »
WOW!! Great thing, that! Works really great and fast!!!
Thanks! :D
