Odd Schematic Editing Behavior
deraudrl
Post by deraudrl »
I'd noticed several times that when I opened some schematics from the forum, modules/primitives were pushed up beyond the top border of the viewport, even if the viewport is moved as high up on the schematic as it will go. Here's a capture to illustrate:
The three modules are copies, only the names changed. Here's the schematic to play around with:
Align.fsm
(94.79 KiB) Downloaded 882 times
There appears to be a correlation with where the mouse cursor is relative to the object when you start dragging it to move it...sometimes you can drrive the name completely off-screen, sometimes only halfway. (I verified that the problem, minor as it is, still exists in the current FS4 alpha.)
And if this is something everybody but me has known about for years, well, just move along, nothing to see here.
Re: Odd Schematic Editing Behavior
You know, after more than 6 years with FS I never noticed that! :shock:
I would suggest you report it in the Help section of the Slack group.
deraudrl
Post by deraudrl »
Spogg wrote:I would suggest you report it in the Help section of the Slack group.
Ok. Is the 'Help' channel the right place for bug reports?
Spogg wrote:You know, after more than 6 years with FS I never noticed that!
I'll see your six and raise you another six! :lol:
I can't believe that I haven't done it by accident many times, especially back in my tiny-screen days; but it's obviously never battered down the door of my conscious awareness!
The "mouse correlation" is something to do with rounding the mouse's "y-delta" to grids, I think - it seems that strips one grid in height alternate between the full effect and only going half-way off.
Yes!
