Freq cross over with gain control
primeposition
Post by primeposition »
cross over with gain output..fsm
(8.02 KiB) Downloaded 1382 times
Hi all,
Looked through some of the forum and found a couple of other users examples so I combined them,
wondered if it could be improved upon.
any ideas give me a shout.
I have found that the right hand box, freezes when I change bits in my schematic. and it looks weird when you move them about.
cheers
Re: Freq cross over with gain control
I'll probably sound like a grumpy grandpa, or a not-so-welcomed picky teacher, but the very first thing you should learn besides creating something is how to connect prims/modules. Avoid crossing lines as much as possible and keep the lines lengths' short. Make use of wireless connectors for feedbacks. Minimize front panels that you only need in the top view.
I'm not telling that because of some style guide or something. No, it is just to let others and yourself have an easier time reading the schematic. Here's what it looked like after a couple of minutes of work:
schematic revised
BobF
Post by BobF »
Hello tulamide,
Say, how did you get those right angle turns in your schematic? I would really love to learn that trick.
Many thanks, BobF.....
adamszabo
Post by adamszabo »
Its in Flowstone options in Advanced called Link Curvature
It's even easier. Without touching your curvature setting, you can right-click a link line and de-select "curved" from the popup-menu. I just don't know, with what version this option was introduced. Probably 3.0.6
BobF
Post by BobF »
Much appreciated guys. Never even knew it was there.
I have an even better idea I will post soon. It would have to be Incorporated into 3.09 though.
Later then, BobF.....
primeposition
Thank you for the feedback. Has anyone got any improvements they would like to share?
any explaintions to why the blocks might end up freezeing ?
Kind Regards
primeposition
Does anyone know how I would go about making the boxes into lines and just having points instead of big resizable boxes?
