Ruby 64bit problem?
adic
Ruby 64bit problem?
Post by adic »
Hello,
I made an example of VST MIDI effect on FS 3.0.6, which works fine on 32bit DAW (Reaper) but does not work perfectly on 64bit DAW (the timing of each note becomes incorrect, that is, out of position for some reason).
midi_transpose.fsm
VST MIDI effect (transposition)
(12.71 KiB) Downloaded 1502 times
