DLL Stream FFT (Finally some progress)
I was reading excellent article by KG about FFT and I decided to recreate everything in green so I can better understand what is going on inside FFT algorithm. My goal is to make DLL stream FFT, but first I must done it using green.
What is not clear to me is this part of the article:
Here is my progress so far...
So, I don't know how to get magnitude and phase and how actually to perform FFT on all frequencies...If we do complex math we can multiply by sine and cosine in a single step. Result will be a complex number – real part will be the magnitude of cosine part and imaginary part will be the magnitude of sine part. We can still calculate the magnitude and phase in very same way. If we do this for every harmonic in the spectrum and plot the complex outputs into graph (3D graph – x = frequency y=real z=imaginary) we have in fact preformed Fourier Transform and we now have the frequency-domain representation of our signal.
- FFT in Green.fsm
- (3.25 KiB) Downloaded 1056 times
Re: Help with green FFT
this post can help you to port to dll?
see the DWB ruby code
http://www.dsprobotics.com/support/view ... =fft#p6433
The problem is that I don't understand that much Ruby code, but if you can explain me some parts I could probably do it...Tronic wrote:this post can help you to port to dll?
Can you comment the code so I can better understand it? I will add question mark for what is not clear to me...
def fft doinverse = true
src = self
# raise ArgumentError.new "Expected array input but was '#{src.class}'" unless src.kind_of? Array
n = src.length
nlog2 = Math.log( n ) / Math.log( 2 )
raise ArgumentError.new "Input array size must be a power of two but was '#{n}'" unless nlog2.floor - nlog2 == 0.0
n2 = n / 2
phi = Math::PI / n2
if doinverse
phi = -phi
else
src.collect!{|c| c /= n.to_f}
# build a sine/cosine table
wt = Array.new n2
wt.each_index { |i| wt[i] = Complex(Math.cos(i * phi), Math.sin(i * phi)) } ???Is this building 2 dimensional array?
# bit reordering ?? What is this doing?
n1 = n - 1
j = 0
1.upto(n1) do |i|
m = n2
while j >= m
j -= m
m /= 2
j += m
src[i],src[j] = src[j],src[i] if j > i
# 1d(N) Ueberlagerungen ???
mm = 1
begin
m = mm
mm *= 2
0.upto(m - 1) do |k|
w = wt[ k * n2 ]
k.step(n1, mm) do |i|
j = i + m
src[j] = src[i] - (temp = w * src[j])
src[i] += temp
n2 /= 2
end while mm != n
src
//usage
real = []
imag = []
@in.fft(false).each {|i| real.push i.real; imag.push i.imag}
output 0, real; output 1, imag
yes, you can manage it like an 2D array, but you have to think it as an associative array "real:part + immaginary:part"
and you can use the <complex> stdlib class in c++
butterfly algorithm....
http://www.katjaas.nl/bitreversal/bitreversal.html
Ueberlagerungen ???
this calculate the overlapped pieces for the windows
Ueberlagerungen ???
Robertocrarswell
Thank you for all great information.
Ok, thanks. Sorry for late response..
I still dont understand what this peace of code is doing.
Is this building sine and cosine of whole array size (one sine cycle in, for example 1024 array) and then getting their complex number (2 arrays are added to get one complex number) and then storing that numbers on each index in wave table array?
wt.each_index { |i| wt = Complex(Math.cos(i * phi), Math.sin(i * phi))
Youlean wrote:wt.each_index { |i| wt = Complex(Math.cos(i * phi), Math.sin(i * phi))
Complex is a number construct in Ruby. It looks like this: a+bi, for example 0.3+0i for 0.3
If you call Complex with two parameters, the first one will be the real part and the second the imaginary part. So this array will have i entries with each entry being a complex number.
If you later need to split the complex into its parts, you just call .real and .imag
a = Complex(1, 0.53)
b = a.real # = 1
c = a.imag # = 0.53Code: Select all
//usage
real = []
imag = []
Ok, I think that I start to getting it... Can someone put this ruby fft into flowstone ruby so I can debug my code in dll more easily?
I think that I was someware ruby fft module but can not find it...
- martinvicanek
Not sure how far you got, Youlean, but if you are trying to understand FFT and ruby does not (yet) feel comfortable then I'd recommend Numerical Recipes. The second edition is free and chapter 12 has it all on FFT, including C-code (or Fortran, if you prefer
Well, I made DFT working so far. Thanks for the tip. I found many C algorithms but I can get it work.martinvicanek wrote:Not sure how far you got, Youlean, but if you are trying to understand FFT and ruby does not (yet) feel comfortable then I'd recommend Numerical Recipes. The second edition is free and chapter 12 has it all on FFT, including C-code (or Fortran, if you prefer).
I have tried this algorithms for example.
The strange thing is that DFT version works OK, but FFT not, it just return me values like they are on input and this is really strange because I tried 3 other FFT algorithms that are doing same thing...
