is there possible making a slide effect with env?
djbrynte
Post by djbrynte »
Im trying to make a slide is this possible with env?
adamszabo
Re: is there possible making a slide effect with env?
Post by adamszabo »
if you make the env control the pitch of the osc then yes, it will not be a real slide, but will give a similar pitch effect
djbrynte
Post by djbrynte »
ah ok thnx adam thats what im already doing :)
with an env follower. i did put attack on 1.5 and release on 0.5 and sound pretty close!
actually adam try this instead it makes real glide.
add env to a stream before osc.
set attack to 0
decay to 0.1 or so
sustain on max
and release on some 0.3 test it whats best because htis makes the glide effect.
also some portamento. it works like a real glide.
Robertocrarswell
Post by Robertocrarswell »
Thank you
