Constrained Rectangle
Hi All
I'm hoping i may be able to get some help with an exe i'm trying to create. I'm trying to create a rectangle within a space that changes raito but is constrained within the space of a second rectangle. It's mainly to workout a projection canvas and then drop 16:9 projectors 'Rectangles' over the canvas.
I thought this would be easy but i can't seem to crack it, It's probably something very simple but i just can't see the solution.
Any help would be much appreciated.
- calc 2.fsm
- (524.45 KiB) Downloaded 935 times
- martinvicanek
Re: Constrained Rectangle
I was not sure from your schematic what your goal is so I'll try to answer your question.
Suppose you have a rectangle with sides a and b, and you want to fit it into another rectangle with sides A and B, while maintaining the aspect ratio a/b. Your scale factor is
scale = min(A/a,B/b)
so your new rectangle will have the dimensions
a' = scale*a
b' = scale*b
Does that answer your question?
a' = scale*a
b' = scale*b
Thanks for pointing me in the right direction. It most definitley helps.
I'm just creating a projection calculator to help me setting up projection on shows. I know there's a few out there already but i just wanted to see if i could do my own.
I really appreciate the fast response thank you. Matt
- martinvicanek
Here is an example.
- FitImageIntoCanvas.fsm
- (783.71 KiB) Downloaded 945 times
Hi Martin
Thank you very much for the example.
It really helps me understand. Sorry for being a bit slow.
thanks Martin, however, where is the rest of the image? lol
- martinvicanek
http://www.lenna.org/full/len_full.html
Warning: may contain nudity!
Thanks, she is nice, but I was just playing around. Teasing us with the half image.martinvicanek wrote:http://www.lenna.org/full/len_full.html
You do know that as moderators we really ought to delete porn.
But this is art, right?
Nice proper real and valid art.
And not porn, right?
- martinvicanek
No, not porn. Art.
I would never post porn.
