Problem with knob
SampleScience
Problem with knob
Post by SampleScience »
When I try to load my own knob, even if I set the right pixel size the knob doesn't work; it just goes around in all directions. Also, I don't see all the options I should see when I watch tutorials on YouTube, I just have a limited set of options in my Animeted Knob module. Any idea why? I've uploaded my file so you can check it out.
crazyknob.fsm
(23.68 KiB) Downloaded 847 times
adamszabo
Re: Problem with knob
Post by adamszabo »
Your sweep angles are wrong, in the knob ruby code change it to this:
@startAngle = 0
@sweepAngle = 360
SampleScience
adamszabo wrote:Your sweep angles are wrong, in the knob ruby code change it to this:
@startAngle = 0
@sweepAngle = 360
Thanks! It worked! :D
