Comparator
BobF
Comparator
Post by BobF »
Hell gang,
I could really use some help from someone who knows code and could code me a simple stream comparator. What I need is this. Comparison of relative states of plus and minus inputs. If the in(+)is greater than in(-), the output is 1, if in(+) is less than in(-), the output is 0. Only two states 0 or 1. This does have to work with streams as I am comparing two waveforms and need a stream of 1's and 0's from the the two compared streams.
For those that know electronics, this is just a simple analog voltage comparator.
Well that's it. Hope someone can help. If so many thanks in advance.
Later then, BobF.....
adamszabo
Re: Comparator
Post by adamszabo »
If I understood correctly you have two inputs? Then this should do it:
streamin in1;
streamin in2;
streamout out;
out = (in1 > in2) & 1;
If in1 is greater than in2 it outputs 1, otherwise 0
Re: Comparator
Sadly I can't help with the code. But as I understand it, the absolute value is to be compared:
+0.6|-0.7
abs(0.7) > abs(0.6)
sign of the greater is negative, so output is 0
+0.6|-0.4
abs(0.6) > abs(0.4)
sign of the greater is positive, so output is 1
the abs function is pretty cpu heavy I've heard, so I don't know how to realize it with DSP.
BobF
Re: Comparator
Post by BobF »
Thanks, adamszabo and tulamide,
Sorry this is late. Just been busy like we all are.
Comments, tips, hits, suggestions, and so on are always very much appreciated.
