Blank Inputs and/or Outputs
aronb
Post by aronb »
Is it possible to make Flowstone Inputs and Outputs do something like this? :?:
Basically, make space between inputs and / or outputs as needed in a module in order to make things line up nicely. Some of my modules are used for different things (like yours are as well) and sometimes I want or need to connect them but don't want a messy schematic.
Maybe adding something like a visibility (Toggle Show in Parent) on the input / outputs is all it really needs... The inputs and / or outputs are placed, they are just not visible.
Thanks,
Aron
adamszabo
Re: Blank Inputs and/or Outputs
Post by adamszabo »
Thats not possible I think
If your module has many outputs/inputs, I recommend using busses. With busses, you don't need a spagetti-monster in between modules.
how to bus.fsm
(693 Bytes) Downloaded 932 times
