Files to Ruby droplist?
I have been searching online about this but no luck, basically what I am after is: to scan a specific directory (and sub directories) for text files, then convert the structure into a string that the droplist understands. So lets say I have some files:
C:\Folder\Category01\01.txt
C:\Folder\Category01\02.txt
C:\Folder\Category02\03.txt
C:\Folder\Category02\04.txt
and it converts it to something like this:
Folder,
<<,Category01,>>,
<<,<<,01,>>,>>,<<,<<,02,>>,>>,
<<,Category02,>>,
<<,<<,03,>>,>>,<<,<<,04,>>,>>
It seems very simple but for us with little Ruby knowledge seems the hardest thing to do
Anyone care to give a hand?
Folder,
<<,Category01,>>,
<<,Category02,>>,
Re: Files to Ruby droplist?
Very interesting idea. Try this ruby code:
provide the " folders_to_hierarchy" method with an array of strings (paths) and it will generate the expected string.
def folders_to_hierarchy(list)
root=Hash.new{|hash,key| hash[key]=Hash.new(&hash.default_proc)}
d=[]
list.each{|path|
d=path.split(/\\/)
name=d.pop
rt=root
d.each{|fold|
rt=rt[fold]
rt[name]=nil
str=to_hierarchy(root,1)
str.chomp(",")
def to_hierarchy(hash,depth)
if hash.nil?
return ""
else
str=""
hash.each_pair{|key,val|
str+=("<<,"*depth+key+","+">>,"*depth)
str+=to_hierarchy(val,depth+1)
return str
For the really tough part, getting the paths, I wanted to recommend the Dir class, because
would be very convenient to recursively search through all folders and subfolders. Unfortunately, as soon as I use it I get a converternotfound error, because Dir seems to expect UTF8, while Flowstone only provides ASCII 8bit.
Maybe someone else could have a look at it? There might be a way to search all folders with Ruby even without conversion to UTF8?
MyCo, TheOm, Tronic? Anybody?
Dir.foreach(rootpath)Maybe someone else could have a look at it? There might be a way to search all folders with Ruby even without conversion to UTF8?
Thanks KG, works great!
By the way, in the user manual there is a function 'schematicLocation' which outputs where the project is located, however it outputs a string like this:
How can one only output the folder? It didnt really explain in the manual.
{:folder=>"C:\\Users\\...", :filename=>"project.fsm"}Re: Files to Ruby droplist?
If you just want to get it to work, you can use rootpath.force_ending("UTF-8"), but this will just pretend that the string is encoded in UTF-8 even though it actually isn't. It will fail for paths that are not representable in ASCII. I have no solution for doing it correctly.tulamide wrote:For the really tough part, getting the paths, I wanted to recommend the Dir class, becausewould be very convenient to recursively search through all folders and subfolders. Unfortunately, as soon as I use it I get a converternotfound error, because Dir seems to expect UTF8, while Flowstone only provides ASCII 8bit.Code: Select all
That's not a string but a hashtable (using symbols as keys). To get the folder path just calladamszabo wrote:Thanks KG, works great!
How can one only output the folder? It didnt really explain in the manual.Code: Select all
schematicLocation[:folder]"There lies the dog buried" (German saying translated literally)
Thank you for having had a look at it. I just wonder, how Flowstone manages it, when using the FileDialog prim? Maybe we should ask MyCo to convert to and from ASCII 8bit for Dir as well (File class already works with Flowstone's path strings, e.g. the result from the FileDialog prim)?TheOm wrote:If you just want to get it to work, you can use rootpath.force_ending("UTF-8"), but this will just pretend that the string is encoded in UTF-8 even though it actually isn't. It will fail for paths that are not representable in ASCII. I have no solution for doing it correctly.tulamide wrote:For the really tough part, getting the paths, I wanted to recommend the Dir class, becausewould be very convenient to recursively search through all folders and subfolders. Unfortunately, as soon as I use it I get a converternotfound error, because Dir seems to expect UTF8, while Flowstone only provides ASCII 8bit.Code: Select all
