Ruby: while statement
jerry
Post by jerry »
I wanted to use a while statement to loop in ruby until a limit switch was pressed.
Ruby gives an error : "excessive processing detected"
See code below:
while @ins[0] == false do
Please advise how to suspend operation until an event occurs.
Embedded
Re: Ruby: while statement
Post by Embedded »
Yes you have created an infinite loop, which is not good in programming terms. Hence FlowStone catches it before it causes your system to crash.
You should use a:
def event i,v,t
with you code inside,not the infinite loop, but what you actually what to do.
def event.fsm
(329 Bytes) Downloaded 1406 times
jerry
Post by jerry »
I tried the event method you provided and I see how it continuously loops, but is there a way to exit out of that loop? Like a while statement I want to loop until a condition is met, perform an action, then exit out of the loop.
I am converting qbasic code that uses while loops and is working fine but I want to convert it to Flowstone/Ruby.
Embedded
Post by Embedded »
Try this, this uses the FlowStone events system to add a delay to the loop and therefore avoids an infinite loop.
while loop break clip.png (29.04 KiB) Viewed 27134 times
while loop break.fsm
(523 Bytes) Downloaded 1357 times
jerry
Post by jerry »
Thanks for the very useful code, I see the delay is working and definitely needed, if I reduce it from .01 to .001 flowstone has an error.
jerry
Post by jerry »
I see how the repeating if statement is equivalent to a while statement but I have not found a way to break out of the event method. If I add a "break" statement in the else loop I get an invalid break error. See below.
else
output 0, "Not Looping"
@count = 0
output 1, @count
break if @ins[0] == false
Invalid break.
DSP
Post by DSP »
The ruby part will happily run up to around 20Khz, ( 0.00005) but if you output this into the GUI system to display it you will overload the PC. Hence while it works ok at 100hz (0.01).
Remember FlowStone is a programming language and therefore you can do pretty much what you want, doesn't mean it always good programming though, so you have to think carefully about what it is you are doing.
