GUI sizes
GUI sizes
Please be aware that the overall size of a GUI is an important factor nowadays. Due to WQHD and 4k, which more and more producers use, the size you see on your Full HD screen is not, what they see. On 4k screens, your GUI is just a quarter of the size, you see on Full HD.
Plugin reviews already take that into account, and will point that out. Here's an example:
Make it as big as possible (larger fonts, larger knobs or sliders, etc), that's mandatory if you want your plugin to be used in (semi-)professional or bedroom studios!
Source: https://bedroomproducersblog.com/2020/0 ... actix-2-0/Unfortunately, the plugin’s user interface is quite small by today’s standards. It is barely large enough for use on an HD screen, but there’s definitely no way to use it on a higher-resolution monitor. Hopefully, a future update will include a larger GUI or an option to freely resize the interface.
- lalalandsynth
Re: GUI sizes
Good point , resizing is essential these days.
Re: GUI sizes
But only possible with the Alpha, right?
- lalalandsynth
Re: GUI sizes
Think so , been a very long time since i used anything else then the Alpha.
Re: GUI sizes
Good point tulamide!
On 2 occasions I’ve had requests for smaller GUIs because they were using laptops with lower than HD resolution. In those cases I made bespoke plugins and they were happy. In another situation a guy wanted a smaller GUI so he could work on the DAW with the plugin view open, and there wasn’t sufficient screen space.
So far I’ve not used the alpha for proper development (mainly so I can share my work here), only testing and exporting 64 bit and helping Johan, who uses it exclusively. This means I’ve not explored re-sizing, so I would have to make 2 or 3 different exports at different sizes. Would you say that users who have 4k monitors are most likely to be using 64 bit plugins only?
Re: GUI sizes
Yes, most likely 64-bit. If you force 32-bit they will give it a try, but 64-bit is the system they use, and so they prefer 64-bit plugins. Some DAWs already excluded 32-bit support (for example Waveform ), and it is rare that one would buy an external bridge just for one or two plugins.
Re: GUI sizes
So if I made a regular 32 bit plugin and 64 bit in say 3 sizes, do you think that would be a good way to go?
Re: GUI sizes
I didn't want to start a new thread, but the discussion of the FS 64 and 32 bit is in here. Will I notice a big difference in performance between the two versions? I assume with floating point math 100% Yes. The main part I am really asking about is with the load on the ruby graphics that ran slower in 32bit will now run smoother in 64bit? I do not currently have access to the 64 bit, I do know it was posted on how to by the Facebook page. Thanks
Re: GUI sizes
I've been trying out the alpha for a week or so now. My current projects ( a midi monitor and a drum machine) are 99% Ruby and very graphics intensive.
To say that I am delighted with the improvement in performance (not just with the graphics but with the program in general) would be a massive understatement.
Re: GUI sizes
It's looking more and more like my FS days are coming to a close. There's just no way I can justify a new PC, just for FS (all my other computer work is on a Mac). Without being able to generate 64 plugs with resizable GUIs, so few people will be using my projects, there'd be no point in continuing. Sure never saw this coming, but that's life I guess.
