Exporting animation/knob as strip.
- lalalandsynth
Is it possible (think I saw this somewhere ) to export a vector animation in FS as filmstrip to use in other programs ?
- trogluddite
Re: Exporting animation/knob as strip.
Nubeat's "knobstrip maker" does pretty much that - though you might need to adapt it a bit if you're using green vectors rather than Ruby to do the drawing. The basic principle of drawing the bitmap piecemeal within a loop should be the same however you draw the knob - just watch out for those yellow view connectors, the routing isn't always clear until you move the modules around!
- lalalandsynth
Thanks mate , will try this out.
