Missing keys in cords
Hey all, here is a bug I've spotted in the latest Alpha, but also in 3.06 and 3.08: When playing a 3 keys chord, it all goes well with octave 0, but only 2 keys work with higher octaves. I don't know if this has already been mentioned, but now it's done
I made a video to demonstrate it
Is this bug confirmed or is it just me?
Re: Missing keys in cords
Can't look at your RAR file yet...I knew there was something I forgot to install when I set up this laptop last month.
Pending getting it opened, and so going only from your description, I'd only note that (1) 3.0.6 has been out 8 years or so, (2) that's a really obvious bug, and (3) it's a bad enough bug to make FS essentially useless. The idea that no one has encountered it before is so improbable that it makes me think, yeah, it's just you.
Then again, I could be wrong.
Followup: I looked at the video on Slack, where it's just an AVI file. Problem is, there's no sound, and I have no idea what I'm supposed to be seeing.
Can't you just post up an example 3.0.6 FSM here that demonstrates the bug?
I know... but it does that to me even with the example synth of SM... No coding of mine in that!!!deraudrl wrote:it's a bad enough bug to make FS essentially useless
And because I really focused on mono-line step-sequencing, and samplers (no polyphony) I've never really paid more attention than that to it...
But now that I'm working on a synth with no step sequencer in it... I'm like what the...
It might be on your side... I do have sound here on the videoderaudrl wrote: there's no sound
If you have SM, it does it to me with the example synthderaudrl wrote:Can't you just post up an example 3.0.6 FSM here that demonstrates the bug?
Ok, just tried the "Example Synth.fsm" that came with 3.0.6: 3-note (and 4-note) chords work fine in every octave my MIDI keyboard will transpose to.
Dunno what to tell ya.
Ok thanks for testing
Have you tried without transpose? just by going up octaves on the keyboard itself, physically?
Also does it work with the PC keyboard? that's what I use, in fact... like chord with x/v/n no problem...
but r/y/i doesn't... (oops i have an french keyboard
) it's the same placement/location for these letters with qwerty, isn't it?
but you saw my vid, didn't you?(with sound I hope
) It doesn't work for me... why? and it does the same with my Nano key controller...
I have a 4-octave M-Audio keyboard...I just used the transpose to get the two octaves at the top and bottom.tektoog wrote:Ok thanks for testing![]()
Didn't try that, don't normally use it. But I would not be surprised if simultaneous-hit chords don't work well on a PC keyboard: it's not really what they're designed to handle. In any case, I would expect variances between different keyboards/drivers/etc anyway.tektoog wrote:Also does it work with the PC keyboard? that's what I use, in fact... like chord with x/v/n no problem...
but r/y/i doesn't... (oops i have an french keyboard) it's the same placement/location for these letters with qwerty, isn't it?
Looked at it on another machine using VLC. The good news is, I heard sound, the bad news is, the video was rotated 90 degrees (to vertical) and smashed almost flat. But what I heard appeared to match the keys being lit up in all cases, take of that what you will.tektoog wrote:but you saw my vid, didn't you?(with sound I hope) It doesn't work for me... why? and it does the same with my Nano key controller...
Haaaa goodderaudrl wrote:I heard sound, the bad news is, the video was rotated 90 degrees
No it does not... only when keys are hit individually, or in chord with Octave 0 - x/v/nderaudrl wrote:what I heard appeared to match the keys being lit up in all cases
the octave above plays well individual keys, but not the chord r/y/i... there should always be 1 or 3 keys playing and if you look closely at some points there are only 2...that's where the bug is...
Could you try it, please? to confirm or not...deraudrl wrote:Didn't try that, don't normally use it
And I also tried the example synth of 3.06 version, the one with arpeggiator, if I press 3 keys on Octave 1 (keys r/y/i) I have no sound at all...
Thanks for your time
I can confirm the bug
-szx ...x doesn't sound here
when I create MIDI in FS there is no such issue, I am always using my code to create MIDI
I'll just try some simple analytics on the MDI coming out of the typing keyboard
Ok, on my Logitech K200 QWERTY-layout keyboard, I (sort of) see the "bug", intermittently and with different symptoms than yours. In my case the 'qwer' row usually works more consistently than the 'zxcv' row, but sometimes both work and then a few seconds later neither will.tektoog wrote:Could you try it, please? to confirm or not...
Be that as it may, I'm not sure it counts as a "bug". Quite frankly, I'm a bit surprised playing chords on a PC keyboard works at all.
