Sampler with configurable loop point
az-terisk
Post by az-terisk »
Hello,
The subject has already been raised on this forum but has, unless I am mistaken, never been followed up.
I'm trying to implement a loop point configurable to a sampler, but despite all my research and tests so far, this has unfortunately remained unsuccessful.
Would any of you have some leads to help me move forward here ? I know that I'm asking a lot of you at the moment, I apologize for that and thank you in advance for your answers.
Good evening to all of you ! :)
tektoog
Re: Sampler with configurable loop point
Post by tektoog »
Hey,
If you search in the SM archives, there's a sample player made by Exonerate at the time.
It's a good schematic to start from...
It's also been improved a lot by numerous people over the time, so you can probably find one version which will adapt to your thinking... ;)
Take care ;)
nix
Post by nix »
Hi mate,
here's a simple sampler I have been working on over the years,
hopefully the right schems are in the zip,
it does include a configurable release loop point in the release version
-the sample will loop while sustaining, then play the tail when the note is released
Phonics sampler.zip
(566.07 KiB) Downloaded 1867 times
az-terisk
Post by az-terisk »
Thank you very much for your answers.
The real idea is to be able to have a sampler able to "loop" the end of the sample thanks to a configurable loop point, in order to bring it a maximum of realism thanks to the repetitive side : for example, on a piano sound mixed with strings (violin ...). Until now, despite searching in the SynthMaker archives and many personal tries, I unfortunately never succeeded in doing so.
Nix, your work is close to what I want to do, so I'm going to study your Schematic and thank you warmly for sharing it with me.
Have a nice weekend ! :)
nix
Post by nix »
hey thanks!
iirc- it was pretty difficult to hack that release in there,
but it should be a start I hope
the idea is to use the required sample/counter index on your loaded 'mem'/.wav
these schems for the alpha are based on that very old schem by Exo,
but I have re-written nearly all of it at one time or other
DSP-Robotron
Post by DSP-Robotron »
The sample fsm doesn't work with the 32bit demo version of FlowStone.
Do I need a different version ?
Is there a 64bit version somewhere that I missed ?
az-terisk
Post by az-terisk »
Hi gang,
Since I wrote that last message, I've been working, in my spare time, on this sampler with this on-the-fly configurable loop point.
The initial idea is to enable the user to define a loop point on the fly, as soon as the sample playback reaches a value that the user himself has defined beforehand: https://ibb.co/RTNdjzp
In principle, it works as follows:
- two wave players ;
- a progress bar for sample playback;
- when the progress bar reaches the value defined by the user-configured loop point on the fly, there's a switch from the first to the second wave player.
After many attempts, I arrived at the result whose corresponding schematic can be seen here: https://ibb.co/7bByDM1
It works, but it's not ideal, as it's rather dirty and heavy, and I think that the use of "green" primitives is at the root of the problem I'm experiencing when reading the sample. Indeed, there's a slight "cut-off" or the sound "skips" slightly when there's a "switch" to the second wave player, which isn't exactly ideal...
My current skills don't allow me to go any further at the moment. If anyone has any ideas or avenues I could explore (ideally with sample diagrams), I'd love to hear from you ! ;)
Thanks a lot.
My first thought is that I would avoid using selectors for the audio path because they’re controlled by green and they can cause a stream interruption when switching.
I’d be inclined to use a rapid cross-fade using stream multipliers controlled by green with a fast de-zip for the crossfade. Experiment with the de-zip time, starting at maybe 20mS…
az-terisk
Post by az-terisk »
Spogg wrote:My first thought is that I would avoid using selectors for the audio path because they’re controlled by green and they can cause a stream interruption when switching.
Thank you for your reply. I've made a few attempts of my own to follow your recommendations, but unfortunately without success. I must be doing it wrong.
By digging around in the forum and in the sample schematics stored on my hard disk, I found Quilcom Bridgit, which seems to exploit this technique. Perhaps I should go down this route instead and try to implement the cross-fade functionality I'm looking for in my own project to see how it renders afterwards?
Thanks again.
Ok, good luck!
If you don’t make suitable progress you could post your schematic here and get help from me and others.
