Math help
adamszabo
Math help
Post by adamszabo »
Hey friends,
I have to revisit an old code with this nasty formula: 0.0001^( SampleRate / ( 10^(( x-1)*4.307) - 4.925e-005 )*600 ), and I have to rewrite this in stream form, which will use way too much CPU because there are too many powers and a division. Are there any math wizards that can help me rewrite this in a much simpler form? It doesnt matter if there are some errors, as long as its close to it. The only variable is the 'x' and a samplerate input.
Thank you!
formula.fsm
(254.63 KiB) Downloaded 1113 times
aronb
Re: Math help
Post by aronb »
I might be able to help... BUT I have a few questions:
1) What are you calculating? Might be a more efficient way...
2) Otherwise is it just that EXACT formula?
3) What tolerances do you need? How exact does what you are calculating have to be...
Thank you,
Aron
juha_tp
Re: Math help
Post by juha_tp »
Try Simplify[0.0001^( f / ( 10^(( x-1)*4.307) - 4.925e-005 )*600 )] at https://www.wolframalpha.com/
MichaelBenjamin
Re: Math help
Post by MichaelBenjamin »
Last edited by MichaelBenjamin on Mon Sep 21, 2020 11:02 am, edited 1 time in total.
juha_tp
Re: Math help
Post by juha_tp »
What is the range for variable "x" ?
adamszabo
Re: Math help
Post by adamszabo »
Thanks guys. This is for a decay calculation on my envelope so it needs to be pretty accurate, but it depends on the formula on how much cpu I can save. The range for the x input is from 0-1 only.
Re: Math help
The formula that is implemented in the schematic should read
0.0001^{1/[600*SampleRate*(10^4.307*(x - 1) - 4.925e-5)]}
For x in the range between 0 and 1, a reasonable approximation for 44.1k is
1 - (0.9939 + 2914*x)/(1 + x*(3102 + x*4356980))
Relative error is less than 1%.
adamszabo
Re: Math help
Post by adamszabo »
Thanks Martin!
The sample rate variable must be dynamic however, as the synth will get the samerate from the DAW. I cannot set it as fixed. Any ideas what to do in that case?
deraudrl
Re: Math help
Post by deraudrl »
adamszabo wrote:Thanks Martin!
Derive the constants in Martin's equation once when the sample rate changes, then use the simplified equation thereafter?
Or maybe just look them up from a table: I suspect the number of different values for sample rate that you need to be able to deal with is rather small.
Re: Math help
Forget my previous post. If the quantity of interest is the decay factor per sample, you need much more accuracy. I can offer the attached implementation using fast powers.
stream_formula.fsm
(121.88 KiB) Downloaded 1113 times
