drum pads
scanz
drum pads
Post by scanz »
got a couple of queries regarding drum pads. in the drum pad test A fsm I would like to know how to make the folder selector work instead of the load button which is connected at the moment. when I link it up it keeps reopening the selected folder over and over without loading a new wave file. also in the machine spogged 2 fsm I'm trying to get the detuner/transposer to work but it just causes distortion. wondered if anyone could figure these issues out.
machine -spogged 2.fsm
folder select problem
(115.16 KiB) Downloaded 974 times
drum pad test A.fsm
detune problem
(99.49 KiB) Downloaded 925 times
kortezzzz
Re: drum pads
Post by kortezzzz »
"machine -spogged 2.fsm"- The problem was the using of the pitch output from the midi to poly instead of using frequency output+turning on the boolean switch inside the counter module which connects the the manipulated frequency to the "PreciseCounter"module.
About the drum pad test A: You should combine a preset manager in this schematic or it would never save the last settings and keep opening the same folder every time.
(machine -spogged 2_fixed).fsm
(117.86 KiB) Downloaded 997 times
(drum pad test A fixed).fsm
(104.38 KiB) Downloaded 947 times
StereoSpace
Re: drum pads
Post by StereoSpace »
Wow! Thanks!
GUI designer
