The Quilcom STAGE: Enhance your stereo!
Hi fellow Flowstoners!
The Quilcom STAGE (STereo Audio Gets Enhanced!) is a mother module which hosts 9 processing modules, each dedicated to enhancing a stereo mix to give added width, localisation, vibrancy and depth, depending on the selected processor. Various techniques are used to achieve this. Of course it can also be applied to individual stems, provided the source is in stereo.
The user can audition each processor in turn, find the sweet spot for its settings, and then do A/B comparisons without interrupting the audio source. Only the selected processor will use CPU cycles and the DAW will recall the settings and selection with the song project file.
There is a user guide included. The VST plugin can be found on http://www.flowstoners.com under Quilcom.
Any feedback from you will be highly valued!
- Quilcom STAGE forum.zip
- (962.94 KiB) Downloaded 1276 times
Re: The Quilcom STAGE: Enhance your stereo!
WOHO!! This magic...
I often work with audio material, and as we all quadrupeds, the stereo image is very important to create good effects, voice acting scenes, and everything else.
Sometimes, it takes something special to create a lush atmosphere, for example when it is necessary to do the voiceovers makeshift lab space, or fantastic garden !,
This processor will allow you to get a tight and at the same time broad and atmospheric sound !!!,
I would put 10 of 10 (I wish you further development)
P/S: (I am not a particularly impressionable, but I know that this is the really cool, I rely on my experience of working with audio, and the creation of advertising, if I'm wrong can follow any responses to kick me, but he made one of the best stereo processors)
Thank you for this!
Thank you for this!
Hello Spogg,
This really turned out cool. Depending on the mono source and what you select with your Quilcom Stage it can really make a mono source come alive. I listened to some old mono lp's for several hours last night with headphones. I like it so much I wish I could turn it into an App for my Android phone. Great job as always.
Later then, BobF.....
Hey thanks guys!
You two made my day
You two made my day
