get list of asio i/o name
hello, i'm korean Flowstone user.
how can i get list of asio available input or output name to string array?
i found component returns list of audio device(asio name) but i don't know how to get list of asio inputs/outputs name.
- q1.png (164.85 KiB) Viewed 34978 times
Re: get list of asio i/o name
right now it's not possible to get the list of audio I/O.
I think we could add a primitive that could output that. I'll add it on our todo list and come back when it's done
OK, that was a quick add. It'll be available in the next release
MyCo wrote:OK, that was a quick add. It'll be available in the next release
Thanks! when is next release day?
and i discovered Flowstone asio maximum support number of channel was i/o each 32channel.
is it impossible more number of channel?
i planning multi channnel audio analyzer system(scope or spectrum etc.) using selectable and routable channel (PC or External audio card etc. all detected i/o device source from PC). like a mixer.
hi, i'm still on flowstone 3.0.6,
my question is if you can do just that of routing multiple audio channel outputs,
I need it for a vst that I made of 4 stereo OSC, it would be 8 output channels
